Back Fire 350 V8
Hi Folks
I am new to the forum but not wrenching. I have a friend with a "72" chevy truck with a built 350. I dont know the actual build but what I can see is this. Holley 750DB w/ hiperf electric pump on a Edellbrock dual plain manifold, headers, camel hump heads, Mallory HEI and a roller cam of unknown specs. The engine runs great and has no problems of the line under full or partial throttle. The problem is it backfires when it gets to higher RPM. If you are cruising on the freeway at 60 and punch it it does fine for a few seconds than starts to backfire. The timing is about 8 BTDC and a total of 38 BTDC the plugs look good at idle and full power. I have checked all the basics and cant find any obvious problems. He brought the truck to me in frustration as three other shops could not fix the problem. The only real build problem I see is that the carb CFM seams a little big to me. Any ideas? |
Lean Mixter maybe
Carb may be running to lean
It is actually popping back through the carb. Timing is correct but I did notice removing vacuum advance slightly improved the problem. I have a feeling you are correct that jets on secondary maybe to small as carb is to large for engine as far as I can tell by standard build specs. I will do another high speed run and shut it down to check the plugs for correct mixture.I have done this once and they looked ok as well as the tail pipe soot is a nice dark tan brown.
If timing is correct and mixture looks good from reading plugs than i would suspect there to be.some faulty ignition components. Could be spark scatter inside the cap from carbon trails.
| blown 350 back fire | sands | Engine | 11 | 05-23-2011 11:52 AM |
| back fire | say10tatoo | Engine | 7 | 02-05-2005 10:41 PM |
| Back Fire Issues | AndyB | Engine | 24 | 01-30-2005 10:10 AM |
| back fire | savman1 | Engine | 10 | 06-18-2004 03:58 PM |
| back fire | DoubleVision | Engine | 2 | 12-24-2002 12:47 PM |
