Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - back fire
Thread: back fire
Old 02-05-2005, 12:16 AM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
Last journal entry: Street Legal
I think I see your problem
I have never used a blue pump but am familiar with the reds. If they are the same other than the regulator. I know your problem.
The red electric pumps have no suction. They have to be installed below the tank and gravity fed. It seems you have the pump in the trunk above the tank. It is unable to keep up to the demand at higher rpm.
Install the pump below the tank. I built a bracket under my trunk for the pump and filter. See attached pic.
PS: That rubber line will not pass safety at the race track. Max of 12" in the entire system from tank to carb.
