Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - back fire in the carb
Old 02-12-2010, 01:07 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
A 1981 Chevy pickup had points? I thought they were all electronic by then? Have you checked your timing with a timing light? Have you checked to see if the outer ring on the balancer spun on the hub? If that happens you will never get your timing right. What condition are the timing chain and gears in?
