back fireing chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2002, 08:19 AM
Post back fireing chevy
i have a 1977 chevy nova with a 305 v-8. i put bow-tie heads on with hedders and a edelbrook intake with a edelbrook 600 cmf carb. i have a back fire up throught the carb. when i punch it (just one) then it takes off. i have run the valve lash 4 times and had the timing from 8 deg. to 2 deg. with no change. can an one HELP!!!
roger60 <img src="confused.gif" border="0">
Old 10-27-2002, 09:41 AM
Post
Is the firing order correct? 1-8-4-3-6-5-7-2 cw
Old 10-27-2002, 11:20 AM
Post
Did you install a manifold with no heat crossover?
Old 10-27-2002, 11:49 AM
matty's Avatar
New Member
Post
....it's a chevy, that says it all
Old 10-27-2002, 12:01 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
Post
I had a fresh motor in my Malibu wagon with a Brand spanking new Edelbrock carb,accel ignition, hedman headers, etc...Only would back fire when it was cold, maybe a choke problem.
Later,
Weimer
Old 10-27-2002, 12:04 PM
Weimer's Avatar
Post
Later,
Weimer
Old 10-27-2002, 02:59 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Thumbs up
You have to adjust the acceleator pump. Thats a lean spot when it does that.You have to adjust the Metering Rods to give you a bigger/longer shot of gas to stop the problem.
Go to this site and it will direct you to the rite carb manufacture. If was a Holly the have a free downloadable manual and trouble shooting guide.
This should help you correct the problem.
http://holley-carburetors.com
Luv the smell of NITRO in the morning.
Old 10-28-2002, 08:12 AM
Mertz's Avatar
Post
I had the same problem with my 428 Pontiac. I used a top end cleaner and it got worse before it got better. I think what finally stopped the problem was getting the PCV system hooked up correctly. It hasn't backfired since. Most times its a stuck valve.
Old 10-29-2002, 08:16 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Post
Check vaccum advance
