back fireing through carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2002, 06:24 PM
New Member
Post back fireing through carb
i just rebuilt a 305 and when it starts it back fires through the carb. igot flames coming out of it
Old 10-01-2002, 06:40 PM
54 Chevy's Avatar
Post
Firery carbs aren't very much fun. It sure gets your attention though.
Verify the plug wiring and firing order.
Set the TDC mark on the crank dampener to point at about the 8 to 10 deg mark (initial timing) turn the distributor so that the rotor is pointing to the number one plug.
If it still want to puke throught the carb then the distributor could be out by 180deg. Pull it and turn the rotor 180deg.
Good luck
Old 10-01-2002, 06:44 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
If it actually starts and then backfires, I would say timing is extremely slow. If it just trys then dies, it is prolly out 180.
Chris
Old 10-01-2002, 07:24 PM
Post
hey,
it sounds like your plug wires could be switched around as stated before. I did this early this spring when firering up my car, i could roast hot dogs over my carb. good luck
Matt
Old 10-01-2002, 10:35 PM
New Member
Post
The simple way, turn the engine until you see the intake valve go dowm then watch the damper and stop it ~15 deg before o deg, drop your distributor in rotor facing #1 (reguardless if it falls in the oil pump shaft) and reconnect your wires, make sure number 1 plug wire on the cap is in proximity of the rotor, pull number plug wire and stick a screwdriver in it and lay it next to your header or block. turn on your key and turn your distributor by hand until you get spark. hold your distributor and have someone else bump the motor until the distributor falls in the oil pump shaft.. tighten it down and she will breath...
Old 10-02-2002, 12:00 AM
New Member
Post
You might have to run your valve adjustment again. You could have an intake valve not closing all the way.
Old 10-02-2002, 02:01 PM
New Member
Post
thanx for every ones help. it runs great. 68chevelless454 got it the valves on the right side was to tight.
Old 10-02-2002, 02:46 PM
bullheimer's Avatar
NEVER use credit cards!
Post
OOOOH, HE'S A CAGEY ONE ALRIGHT!!
Old 10-02-2002, 05:04 PM
4 Jaw Chuck's Avatar
Post
Roasted marshmellows anyone? :p
— Han Solo
Old 10-02-2002, 05:05 PM
New Member
Post
not to sound stupid but what does cagey mean
Old 10-02-2002, 06:53 PM
Post
Colloquial US country saying. This means the fella sorta standing around on the periphery of things that knows exactly what's happening and how to cure or complete a problem vexing the crowd.
Whew. Didn't really knew I knew that. I need a beer and that's the truth.
