Back up light switch on a hurst indy 3 speed shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2005, 08:21 PM
junkyardjeff's Avatar
I have a hurst indy 3 speed shifter in my 65 galaxie and would like to hook up a back up light switch,did or does hurst make a switch kit or will I have to fabricate one my self. Jeff
Old 11-02-2005, 06:10 AM
302 Z28's Avatar
Not aware of whether one was offered or not, but it is a relatively simple matter to construct one. Use a micro switch from Radio Shack, attach it to a bracket fabricated from an aluminum strip. Mount the bracket so the reverse arm on the shifter contacts it when in reverse.
Vince
Old 11-02-2005, 12:45 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I have a B&M shifter. It came with the neutral safety switch but the back up light switch had to be purchased separately. I just put a toggle switch on my dash to turn them on.
Old 11-02-2005, 10:41 PM
Hurst/Mr.Gasket makes a switch (pn 248-0003) for the Competition Plus shifters that may work with an Indy Shifter, maybe with a little fabrication.
You can ask Hurst at: http://go.mrgasket.com/AskTechFormHu...aspx?BrandID=2
If you use a switch on the dash, be sure you use a pilot light. Otherwise you'll look silly driving around with your backup lights on. You also might be tempted to use them as tailgater medicine, which sometimes works real well.
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Fuse blows Horn dome light and the back hatch th2hh Electrical 3 08-24-2003 07:44 PM
5 speed tranny with forward shifter? Warm_Spit Transmission - Rearend 2 08-13-2003 08:09 AM
light switch jezer69 Electrical 0 11-15-2002 08:47 PM
GM 6 speed - shifter chevypu Transmission - Rearend 1 03-13-2002 05:21 AM
