back up lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2011, 06:27 PM
69Bowtie's Avatar
back up lights
Need some help. Back up lights don't work on a 69 Camaro. Bulbs are good, could it be neutral safety switch? If it is where is it located?
Thanks
Old 07-31-2011, 01:29 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
If neutral start switch has a pink and a green wire connected, these wires are for the backup lights. To test, disconnect the wires and touch them together. If the lights work the switch could be out of adjustment or shot.
If the turn signals work the fuse is OK because they are on the same fuse as the backup lights.
vicrod
Old 08-01-2011, 07:52 AM
bubbahotep's Avatar
He asked for the location of the switch
Uneducated guess: steering column near your shin when you drive?
Old 08-01-2011, 05:51 PM
or maybe by the shifter itself.. i.e. console
mark
Old 08-01-2011, 06:22 PM
69Bowtie's Avatar
Thanks everyone
Having issues with back lights on 96 chevy s10. eric32 Electrical 17 06-19-2009 06:18 PM
Back up lights on a 4 Speed. shad88 Transmission - Rearend 4 10-18-2006 02:09 AM
no running lights in the back 94 chevy s-10 jca132 Electrical 6 08-01-2004 10:09 AM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 03:20 PM
Reverse/Back-up Lights js34Ford Electrical 4 01-09-2002 02:19 PM
