Back up lights on a 4 Speed. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2006, 07:02 PM
I'm going to be doing an auto to manual swap in a 69 Nova. Just wondering how the back up lights are turned on by putting tranny in reverse. I'll be using a Saginaw 4 speed. I assume there is some type of mechanical linkage from the tranny, but am not sure of how it works or what it looks like. Any help will be greatly appreciated. Thanx
Old 10-15-2006, 07:38 PM
On the bottom of the steering column, near the floor there is a switch with various wires. This is the neutral safety switch and reverse lights switch.
Reverse lights will have to be triggered from shifter linkage (use Hurst) and neutral switch from clutch pedal.
Old 10-16-2006, 10:06 PM
The factory used a linkage from the trans to the column called a backdrive linkage in GM-speak. You might be able to find those parts, but I wouldn't hold my breath.
You might be able to cobble up a bracket for a switch that you could activate with the reverse arm or lever.
Old 10-17-2006, 06:54 AM
65 Imp SS's Avatar
Take a look at hurst #248-0003, it is a hurst backup light switch kit.
Old 10-18-2006, 02:09 AM
Thanx that's just what I needed. I ordered it as soon as I read the post.
Bring Back the RWD V8 Monte Carlo!! Fragzem Hotrodders' Lounge 18 10-16-2004 11:35 PM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 03:20 PM
my newborn crapped his die-dees: l.e.d lights all blew up bullheimer Electrical 4 08-16-2002 08:44 AM
