Back up wire only - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2010, 08:59 PM
Back up wire only
I have blacked out my tail lights and flipped the handle it looks sweet. I'm using a light bar it's off during the day until you hit the brakes, use signals, or use reverse. I had tapped into the tail light harness for the reverse light but at night only red is supposed to be on always but as long as I am tied into that harness both red & and white are on constant. anyone know where I can pull reverse signal or can suggest a route for running a line. The bar came with a plug just to plug right in but the reverse has to be hard wired in I can do with out it but, it would be nice to have some light too see.
Old 09-08-2010, 10:07 PM
If you want the light to come on when the transmission is in reverse, you could wire it into the existing back up light circuit.
Old 09-09-2010, 06:43 AM
are you saying run it to the fuse box are is there another junction to tie into?
Old 09-09-2010, 10:08 AM
Where is the liht bar mounted? If it's at the back of the truck, you have to find the wire that powers the stock back-up lights under the vehicle, and join in to that. Probably have to make your own junction.
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 01:50 PM
GM Alt Singe wire to three wire streetrodderdoug Electrical 10 05-26-2007 05:23 PM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
