Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - backfire
Thread: backfire
Old 04-14-2013, 02:18 PM
57 willys 57 willys is offline
Originally Posted by 33Willys77 View Post
Is that 262 advertised duration with 512 lift? Solid, hydraulic, roller, flat tappet? Do you have a grind number so we can see the specs? What is your compression ratio? Wieand intake... but dual or single plane? So far, it may just be a simple lean tip in. Is the pump set correctly too? I can't tell you much for intial timing yet, but I would think 12-14 would do much better. How do you have your curve set on the distributor? Using vacuum advance or mechanical?
There, answer these any we may have a little better picture of what you have.
xtreme 4 x 4 flat tappet hydraulic cams
INT. 262 EXH. 270 INT. 218 EXH. 226 Lift INT. .493 EXH. .512 lobe sep. 111 degrees Roller lifters compression ratio 10 if I remember right. Weiand intake dual plane Set from Holley probably should check I'll try 12 -14 on timing and to fatten up the carb that would mean to turn the screws in? And not really sure how to adjust the rockers. I never had rollers before. Thanks for the help. It is in a 57 Willys Wagon with 456 gears and an automatic. Pertronics distributor vacuum advance
