-   -   backfire (http://www.hotrodders.com/forum/backfire-231798.html)
57 willys 04-13-2013 12:57 PM
backfire
Built 302 Ford 670 Holley Truck Avenger. Off Idle stumble, and backfires through the carb sometimes. Why? 700 RPM, 6 degrees BTDC.
vinniekq2 04-13-2013 01:42 PM
try more static timing
33Willys77 04-13-2013 03:44 PM
What do you mean by built? Give your cam specs, trans type, stall speed if auto and so on. I am sure off the top you will need more intial timing as Vinniekq2 stated.
57 willys 04-13-2013 05:13 PM
30 over 2 valve relief pistons, 160 150 on the valves, 262 512 comp cam roller tip rockers, weiand intake shorty headers, stock converter, c6 automatic, 456 gears, 4-wheel drive. Seems to pull down flat spot until you nail the throttle but when crawling that's when I get the burp out of it. Not really sure where valve adjustment is now it's been a long time.
57 willys 04-13-2013 05:14 PM
How high does it need to be?
33Willys77 04-13-2013 06:03 PM
Is that 262 advertised duration with 512 lift? Solid, hydraulic, roller, flat tappet? Do you have a grind number so we can see the specs? What is your compression ratio? Wieand intake... but dual or single plane? So far, it may just be a simple lean tip in. Is the pump set correctly too? I can't tell you much for intial timing yet, but I would think 12-14 would do much better. How do you have your curve set on the distributor? Using vacuum advance or mechanical?
There, answer these any we may have a little better picture of what you have.
bondo 04-14-2013 09:21 AM
Ayuh,.... Sounds like it's goin' Lean,....
Richen up the fuel abit...
57 willys 04-14-2013 03:18 PM
xtreme 4 x 4 flat tappet hydraulic cams
INT. 262 EXH. 270 INT. 218 EXH. 226 Lift INT. .493 EXH. .512 lobe sep. 111 degrees Roller lifters compression ratio 10 if I remember right. Weiand intake dual plane Set from Holley probably should check I'll try 12 -14 on timing and to fatten up the carb that would mean to turn the screws in? And not really sure how to adjust the rockers. I never had rollers before. Thanks for the help. It is in a 57 Willys Wagon with 456 gears and an automatic. Pertronics distributor vacuum advance
vinniekq2 04-14-2013 03:44 PM
mixture screws out will fatten idle only. do you know how to change jets?
57 willys 04-14-2013 04:04 PM
will that make idle go up
vinniekq2 04-14-2013 05:25 PM
everytime you change something in the carb,tweek the mixture screws
