Backfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2004, 01:53 PM
caminoguy55's Avatar
Backfire
I'm having difficulty getting rid of a WOT backfire. Running 350sbc, edelbrock 1406, Mallory HEI, mild cam and vortec heads. My timing is about 12-14 degrees static advance with 24 degrees mechanical. I have tried lighter springs in the HEI and different jets and rods in the carb. No luck yet. Any suggestions??
Thanks
Old 04-20-2004, 03:12 PM
Siggy_Freud's Avatar
The 1406 is an economy designed carb. Does it do it when you go WOT from a dead stop or anytime you jump to WOT?
I was using a 1406 carb on my 350 and no matter what I did to the sucker it would always give me a pop from a stop to WOT.
Bringing history and technology together.
Old 04-20-2004, 09:36 PM
Siggy..That was exactly the problem, but today I solved it. I went a bought a Holly Street Avenger 670. Its like a new world. Maybe what they say about Edelbrock vs Holly is true. My guy at the parts store said he also had the same problem with a 600 Edelbrock. When he put new heads on the carb just wouldn't keep up. He tried everything too. Nothing worked until he put a Holly on it.
Caminoguy
