Backfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2005, 04:02 PM
Backfire
I have a 351 clevo that runs fine at idle and when you pull away gently but if you give it too much gas then it back fires through the carb, when the car is run for a while it seems to go away? It has just had the original dizzy replaced with an electronic one and the timing is set sweet.
Old 11-04-2005, 05:13 PM
hi ...
try that post
backfiring.....why?
Old 11-04-2005, 06:16 PM
engineczar's Avatar
usually a pop from the carb is due to a lean spot. Sounds like when the engine is too cold there's not enough choke which is why it goes away. Check the float level, fuel pressure, accel pump (etc).
In your case I'd also take a peek at the timing. 10-14 btdc and 36 full advance.
Old 11-04-2005, 06:49 PM
sbchevfreak's Avatar
Licenced Automotive Technician
What Czar said.
Old 11-06-2005, 08:18 AM
Guy Hiltz's Avatar
Backfire
I had backfiring problems with my BB Chevy and it turned out to be the bronze distributor gear was wore out
Old 11-06-2005, 10:18 PM
Backfire
Thanks for your input I will give it a go and let you know how I get on.
Old 11-11-2005, 07:11 PM
backfire no more
Thanks for all your help, I sorted out the choke and fixed the vacuum pipe connected to the dizzy then reset the timing and she runs all sweet now.
Small backfire from Carb...Chevy 350 interro1 Engine 7 07-15-2005 02:00 PM
Backfire geostang351 Engine 4 05-28-2005 09:17 PM
Backfire through exhaust SAATR Engine 9 01-19-2005 09:27 PM
Backfire through carb... please help ecrusch1987 Engine 8 11-26-2004 05:45 PM
Carb Backfire!!!! 68firebirdguy Engine 4 02-20-2004 05:55 AM
