Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - backfire through carb
Old 04-23-2010, 03:47 PM
automotive breath's Avatar
automotive breath automotive breath is offline
Kelly, try a larger shooter size on the primary side of the carb.; also check to
make sure there isn't any play in the pump shot arm.
Also check ignition advance at idle, are you using a vacuum advance?
