Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Backfire through Carb?
Old 09-02-2010, 09:21 PM
sps_sac's Avatar
sps_sac sps_sac is offline
The springs are the the standard which came with the AFR heads. I compared them to the Comp cams spring specs and they were very close to the same. I did shim them up just a bit to add a few pounds and even them all out. I think maybe the ramps on the aftermarket (Comp) cam are a bit steep and along with the roller, cause the lifters to pump up. Haven't had time to get back into the engine. Will likely be Tuesday before I can test this theory to see if it works.
