backfire through carb please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2010, 12:00 PM
my chevy 350 ran great before i installed an edelbrock manifold on it
It stumbles off idle and if you give it gas it backfires through the carb.
To install the HEI distibutor i bump the engine around to feel it push out air, but i feel air both times, but one time is more forceful than the other so i removed the valve cover and made sure both valves were closed. i also put a compression gauge on and one stroke pushes oiut 30 psi and the next stroke pushes out 60 psi. so i chose the 60 psi stoke. when the air pushes out the timing mark is about 12 o clock.
After i feel the air push out i bump it a little more to get the timing mark at zero on the timing tab, i can usually get it pretty close. Then i stab in the distributor so rotor is pointing at about 5:30 pointing to number one post on the cap and vacuum anvance is pointing to #6. firing order is 18436572 with accel wires. I've done this several times. My timing light is lighting and i see the mark is under the tab, the tab is painted so i don't know exactly where it's at, i can see zero and all the dash marks, it's about 3 marks before zero right now. Carb is holley 80457-3, I've taken it apart and cleaned it with gumout carb cleaner, put new gaskets in. I've checked for vacuum leaks and didn't find any. I adjusted float level so it's just under the sight plugs. I replaced the power valve three times. I actually installed the manifold twice with new gaskets to make sure there were no leaks.
What am i doing wrong? i'm really frustrated, please help
one more thing, the fast idle screw is backed out all the way, i don't see how it works because there is a red plastic lever that pushes it open and the choke push rod is mounted under that, if i tighen the fast idle screw the red lever pushes the choke closed rendering my electric choke inoperable
Old 03-11-2010, 06:00 PM
The mobile view is crap
take a can of carb cleaner and spray around where the gaskets are to find the intake leak. It sounds like you have a vacuum leak somewhere.
Old 03-12-2010, 01:05 PM
Thanks for the reply, i went out today and bought carb studs and a new gasket (i was using bolts). After i put that on i sprayed carb cleaner along both sides of the intake and around the base of the carb. I didn't notice any change in idle. I checked all the intake bolts to make sure they were tight, i found one that turned a little more, but it still backfires when i git it a lot of gas. I appreciate your help you got any more ideas? I'td be nice if there were someone in the dayton ohio area willing to come look at it.
Old 03-12-2010, 02:08 PM
the carb cleaner just pooled and sat until it dried
Old 03-12-2010, 05:20 PM
where do you have your timing set?
What springs/weights in the ditributor?
Are you unplugging and capping the vacume advance when you time it?
Old 03-12-2010, 05:46 PM
My timing light is lighting and i see the mark is under the tab, the tab is painted so i don't know exactly where it's at, i can see zero and all the dash marks, it's about 3 marks before zero right now. The stock springs and weights.
No. It won't stay running when i unplug the vacuum advance and plug the port.
Old 03-12-2010, 05:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Scratch the tab off so you can see the timing marks so then you can time it correctly. You say you took apart the carb, have you done any adjustment to it? air fuel mix could be off need tweeking alittle or the floats are out of adjustment, are you are sure it is time now? JMO
Cole
Old 03-12-2010, 08:17 PM
i adkusted the floats so the level is just under the sight plugs, i screwed in the mixture screws till it almost dies then back them out 1 turn
Old 03-12-2010, 08:27 PM
eloc431962's Avatar
Wiki Edits: 37
Did the engine smooth out when you brought it out one turn? Did youdo this while it was running?
Cole
Old 03-14-2010, 11:47 AM
yes, i made the adjustments while it was running and it sounds smooth until i give it gas
Old 03-14-2010, 12:00 PM
bondo's Avatar
Ayuh,... For whatever Reason,... It sounds like it goin' Lean...
Might have something to do with gettin' things Close enough...
In Mechanicin',... Close Enough Never is,...
That's Why Specs are printed for about Every aspect of the things We work on...
Old 03-14-2010, 12:03 PM
barnescole's Avatar
double and triple check your plug wires. sounds alot like mixed up wires, and it is easy to do when reinstalling dizzy.
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 11:50 PM
Holley Carb Backfire DeathRattle Engine 9 12-27-2006 06:44 PM
Small backfire from Carb...Chevy 350 interro1 Engine 7 07-15-2005 03:00 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 03:38 PM
backfire in carb? help? unibrowarrior Engine 26 08-27-2003 09:42 PM
