Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - backfireing through carb at low rpm
Old 02-01-2013, 08:14 AM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Timing set as it should means nothing. Get a timing light and check it. Start at 12 degrees initial. Disconnect and plug vacuum to the distributor when you set it. You might need to go up to 16-20 degrees too.
