Backfiring Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2008, 03:19 PM
bluesman123's Avatar
Afterfiring Question
I have just completed my first total rebuild of a Chevy 383, and now I hear occasional afterfiring through the right exhaust pipe (no H or X pipe crossover). The engine runs a Holley 670 Street Avenger and has the GMPP Hot cam but with 1.5 rockers instead of the 1.6. There also seems to be a little roughness between 2000 and 3000 RPM. I have pulled all the plugs and they all look the same...not enough time on them to tell much. The timing was initially set at about 12 degrees and I haven't gone back to check on that. I set the valves with the engine off but it was cold when I did it, if that makes a difference.
I would really appreciate any suggestions on where I should start looking.
Dave
Old 03-23-2008, 07:07 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Check for vacuum leaks, especially the intake gaskets, & vacuum lines. Back fire through the
exhaust is caused by an air fuel ratio imbalance,
if it's to lean you might get a pop in the intake,
to rich may get one out the exhaust.
Good luck,
Rich
Old 03-23-2008, 07:20 PM
Oh man this is so embarassing!! I found the problem...I had swapped the wires for 6 and 8. I can't believe how much time I spent doing and re-doing everything. So everything solved...runs great!
Dave the Doofus.............
Old 03-23-2008, 10:05 PM
Hi,
Glad you found the problem.
Rich
Old 03-23-2008, 11:32 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
dont be embarrassed my girl friend has a 01 alero and it would start if you boosted it and wouldnt start or put lights on the dash when the key was on. I found out when I replaced the battery I didnt tighten the positive battery terminal all the way and it rattled loose, spent $390 on a new alternator for a loose battery wire ...!
Old 03-24-2008, 08:07 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Just a quick question...you mentioned you had 1.5 rockers "instead of the 1.6" is that something specific to the cam you chose? Small block Chevy's come with 1.5's stock. I am just a little confused by the wording.
Old 03-24-2008, 11:40 AM
You're right, they do usually come with 1.5 rockers. The GMPP Hot cam was introduced as part of an upgrade kit, originally for LT1s I think, and that kit comes with 1.6 rockers. I might add that this kit does not carry a CARB approval number. Anyway, as a $$ saver, I put the heads together with some stock stamped-steel 1.5 rockers I had. Eventually I will upgrade to 1.6 rollers, mostly for the cool factor I suppose. The heads are the SDPP modified vortecs so they can take the extra lift.
Anyway, I managed to put maybe 20 miles on it last night and it runs great. A little lumpy at idle but very torquey at low RPMs.
Dave
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
