Backfiring truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 02:02 AM
Backfiring truck
My pickup has been backfiring bad when i take off and it tries to die or does die, it also does it when im goin down the road and romp down on it, ive replaced the plugs and wires and it didnt help, it has the 350 small block, any help is greatly appreciated
Old 07-22-2012, 03:37 AM
Cridder's Avatar
Last journal entry: 310 Small Block Chevy
backfire when i tromp
With the little info you have provided, and that just starts happening out of the blue, Im gona said you have a lobe going flat on the cam.
Have you run the motor hard lately? gonzo run? monster burn out? no zinc in the oil, time for a lobe to die!
Old 07-22-2012, 08:52 AM
RWENUTS's Avatar
Check your timing first. Sounds like it's retarded. Try for 12* btdc.
The Following User Says Thank You to RWENUTS For This Useful Post:
1972GMC_C/15 (07-22-2012)
Old 07-22-2012, 11:17 AM
Banned User
If backfiring occurs only on deceleration/letting off the gas, what would this indicate?
backfiring 79chevy4x4 Engine 32 01-20-2007 03:37 PM
backfiring 1980Impala Engine 5 03-15-2004 05:34 PM
backfiring zipfactor Engine 2 12-07-2003 06:40 PM
backfiring zipfactor Engine 13 11-09-2003 09:28 PM
backfiring 55relic Engine 10 06-07-2003 07:41 PM
