backing plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2007, 08:46 PM
backing plates
hi there guys just wondering if any one can tell me if backing plates off dodge truck will fit 8 and three quarter rear end the ones i had were ten inch but when i sand blasted them they fell apart found two real good ones on a truck they will bolt on but they are eleven inch also will they fit 14 inch rally wheels i am putting v8 in so up grading brakes on a body from 9 inch to 11 inch if they fit. you know what they say bigger is better thanks fellows any help would be great ray
Old 02-14-2007, 11:44 PM
powerrodsmike's Avatar
Wiki Edits: 161
I don't know if all Dodge axle flange to rear end housing offsets are the same.
I would check the offset of the axle to the end of the rear end housing, and compare between the truck and the car..
If the drums from the truck are wider, then the drum may hit the backing plate before it seats on the axle flange if the offsets are different..
That is where I would start.
Later, mikey
Name:	hub offset.jpg
BE different....ACT normal.
Old 02-15-2007, 02:38 PM
thanks for the help i will try to find this before i put them on any info is much appreciate thanks alot ray
Old 02-18-2007, 08:29 PM
backing plates
Originally Posted by valiant
mickey just wanted to let you know these backing plates will fit as long as i use two and a half inch drums and shoes also found out that backing plates off a 2000 dakota will fit the eight and three quarter rear end good to know ray
Rebuilding my Rear Drum brakes from bare backing plates!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! chevymastermind Suspension - Brakes - Steering 7 11-15-2006 06:58 PM
question about c4 friction plates desman Transmission - Rearend 2 06-07-2006 07:39 PM
Need Rear Brake Backing Plates Paul51 Hotrodding Basics 1 05-06-2006 09:53 PM
1968 12 bolt diff with 76 backing plates mick487 Introduce Yourself 0 08-30-2004 07:33 AM
No backing plates rakundig Suspension - Brakes - Steering 6 01-02-2004 12:53 PM
