backing plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2013, 11:27 AM
backing plates
I have a clearance problem with the wheel cyl and the flex line hitting the spring shackle on my 1931 ford axle. Can I rotate the backing plate without creating any new problems? will bleeding the brakes be a problem? I am adding juice brakes to this 1931 frame and axle.
thanks
Old 10-18-2013, 11:42 AM
techinspector1's Avatar
Wiki Edits: 326
I can't visualize the problem, but I would have no problem changing things around, as long as the bleeder screw is toward the top of the wheel cylinder. If it's on the bottom, it's useless.
Old 10-19-2013, 03:30 PM
I had to do this recently on an A rear end in an antique race car restoration. I had no problem bleeding it, but I only rotated it enough for line clearance.
Disc Brake Backing Plates 345 desoto General Rodding Tech 6 01-01-2009 09:43 AM
Super Bell Backing Plates ibarodder Suspension - Brakes - Steering 1 07-20-2007 10:24 PM
backing plates valiant Suspension - Brakes - Steering 3 02-18-2007 08:29 PM
Need Rear Brake Backing Plates Paul51 Hotrodding Basics 1 05-06-2006 09:53 PM
No backing plates rakundig Suspension - Brakes - Steering 6 01-02-2004 12:53 PM
