Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - backing plates
Thread: backing plates
Old 02-15-2007, 12:44 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
I don't know if all Dodge axle flange to rear end housing offsets are the same.
I would check the offset of the axle to the end of the rear end housing, and compare between the truck and the car..
If the drums from the truck are wider, then the drum may hit the backing plate before it seats on the axle flange if the offsets are different..
That is where I would start.
Later, mikey
Name:	hub offset.jpg
BE different....ACT normal.
