backing for sand paper - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2005, 07:18 PM
antiquecar's Avatar
old car nut
I have alway had a problem finding a backing for sand paper when sanding concave and convex surfaces which I find a lot in working with old cars. I have used radiator hoses and flexible rubber pieces but I think I finally found the solution. I had a lot of mouse pads and wrist rests laying around last night and needed to do some wet sanding on some wheel rims. If you take a mouse pad or if you want a thick pad a wrist pad and cut it. It makes a great backing pad. One side of the pad is usually textured and grips the paper. The other side is smooth. Depending upon the pad you can get a stiff pad or a soft pad and because it is a rubber based you can use it in water. If you want to contour it just use a knife and some 80 grit paper and you can make it any shape you want. I also use drip irrigation hose held by small suction cups to provide a constant water source on large flat surfaces. Hope some one can use this idea and improve on it.
Old 07-12-2005, 07:43 PM
302 Z28's Avatar
3M makes a foam backed flexible sanding pad that can be used wet. It comes in various grits and is about 3/16" thick.
Vince
Drilling backing plate bolts? 69ChevelleAddict Suspension - Brakes - Steering 4 07-11-2005 10:52 AM
how to remove backing plate on 68 firebird 67bird Suspension - Brakes - Steering 3 05-10-2004 06:45 AM
foam for interior panel backing bct Interior 1 02-08-2004 08:52 AM
No backing plates rakundig Suspension - Brakes - Steering 6 01-02-2004 12:53 PM
mopar 9 1/4 backing plate for brakes shortsuperbird Transmission - Rearend 2 10-28-2002 12:46 AM
