Backup light fuse keeps blowing - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 08:02 AM
octanejunkie's Avatar
Registered Looser
Last journal entry: Background: why I am here
Checked all the wiring to my backup lights, which are switched off the neutral safety switch on my column, and find no shorts... but it seems they only work once or twice and the fuse burns out again!
I called Painless, whose harness I am using, and they advised me to check the tail lights themselves and look for minor shorts to ground at the light sockets, found none.
Could my neutral safety switch be bad, how to test?
Old 11-07-2010, 01:45 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Try this.
Remove the bulbs.
Remove the fuse for that circuit.
Connect a test light across the fuse clips.
Put the shifter in reverse. Wiggle the shifter to see if the test light lights even for a flash, the switch is likely the problem.
If not wiggle the harness.
Put the bulbs back one at a time. Eventually you will get the test light to light.
There is a remote chance that one of the bulbs is bad even if it works.
vicrod
Old 11-12-2010, 07:37 AM
Registered Looser
I'll try it today, thanks!
If it is the switch, I am not sure what vehicle my column came out of. The switch only has 2 sets of terminals, neutral safety and backup lights... I did a quick search at Napa and found one that looks similar, ECH NS6537, it's $25 - seem pricey for a switch...
Old 11-12-2010, 04:29 PM
EOD Guy's Avatar
5 bucks out of a junkyard
Old 11-14-2010, 08:11 AM
Registered Looser
It's the switch
I pulled the connector off the switch and have been jumpering it with a small wire when I need backup lights, works fine
Found the target vehicle for a new switch too, 85 Chevy P20/P30 van; I'll try the yards this week
Old 11-25-2010, 02:07 AM
i never had a vehicle with backup lights worth using
when I switched to a floor shift, I didn't even bother with the NSS or backup light switch.. but eventually I did hook the up since NHRA rules require the NSS...
Old 11-25-2010, 10:33 AM
Registered Looser
Turns out it wasn't the switch. I tested it with a junkyard switch and it blew the fuse too.
I re-insulated the pigtail as I suspected it was shorting against the column and the fuse has been fine, lights working, ever since.
The backup lights are super bright and do help vs. not having them, but I agree what would really help sometimes would be a reverse head lamp
Old 11-25-2010, 04:11 PM
EOD Guy's Avatar
I installed mini fog lamps from advanced auto (19.00) hidden under the bumper and tied them into the backup light circuit....... works very well
Keeps blowing out my fuse! redfish211 Electrical 3 10-21-2010 07:33 PM
Blowing a fuse!!!! rhinz1966 Electrical 3 05-25-2010 09:26 PM
horn and dome light fuse keep blowing sapsz28 Electrical 12 04-14-2009 03:02 PM
backup light switch location 19nova72 Transmission - Rearend 2 07-11-2005 08:23 PM
How many Forum members.............. Stitch Hotrodders' Lounge 29 03-11-2004 07:31 AM
