backup light problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 08:03 PM
firefighters like hotrods too
im working on a 95 chevy truck that has a 5 speed tranny and i cant figured out why they are not working. the blubs are good. is there a swicth some where that could of gone bad?
Old 10-25-2010, 08:36 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
yes there is a switch; read this could help you.
info is on the 1997
FIRST;
check the fuse the backup lights is a 15amp fuse
If you have electrical skills you can place an Ohm meter across the switch after you get it out and then press the ball in to see if the circuit closes.
on the right side of the transmission there are two electrical connections plugged into the transmission. The front most of these two is the backup light switch. the wires going to it should be Pink and Light Green.
If you place the vehicle in any gear except reverse you can easily remove this switch. Just unclip the wire and use a 24mm deep well socket. The switch has a small ball on the end of it that is depressed when the vehicle is in Reverse.
brake light problem cornfieldcars Electrical 20 10-19-2010 07:54 AM
Is light brown haze on steel a problem Slickriffs Body - Exterior 9 10-04-2007 05:38 PM
head light problem mike martinson Electrical 10 08-12-2007 06:17 AM
brake light, turn signal, tail lamp problem worknprogress72 Electrical 6 01-06-2006 12:20 AM
another light problem comet boy Electrical 3 10-26-2005 05:32 AM
