backup light switch location - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2005, 11:03 AM
19nova72's Avatar
i have a 72 nova that came originally with a powerglide and column shifter. The previous owner put a th 350 in the car but it still has the column shifter. I just ordered a hurst quarter stick with a forward shift pattern and I am wondering if I will be able to maintain the backup light switch using this shifter or if i will have to make my own switch. I am not sure where the backup light switch is located in the car. Does anyone know where the backup light switch is located in the this car or if it will work with this shifter?
Any help is appreciated.
Ian
Old 07-10-2005, 12:01 PM
IF I am not mistaken...the backup light switch is on the column.
Make sure you hook up or fabricate a neutral start switch for your new shifter. It would be easy to fabricate a ball type switch and make it a back up light switch also.
Some early GM vans ( 1969 to about 1972 ) had a switch on the Turbo 350 case that served as a neutral start, back up light switch.
I have one on my 32 Ford roadster ( with a 400 Turbo ).....works great
Old 07-11-2005, 08:23 PM
19nova72's Avatar
thanks for that info. I forgot about the neutral start switch. im guessing thats in the column on my car too.
bad brake light switch on master cylinder? flamedfordbronco Electrical 3 07-10-2005 05:34 AM
Backup Lights Switch Question horvath Electrical 5 03-05-2005 06:47 PM
Ford Light Switch....Please Help. Coleman396 Electrical 1 11-16-2003 01:35 AM
Back Up Light Switch 1965-Mustang Transmission - Rearend 5 11-10-2003 09:14 PM
Signal Light switch keep geting stuck... 72 Z28 Electrical 3 12-15-2002 02:45 PM
