Is this bad??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2005, 09:26 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Is this bad???
i am rebuilding a Super T-10 (my first time). last night after disassembling the main shaft i noticed damage on the reverse slider gear splines. i think this area is covered up the rear bearing retainer so it shouldnt be a problem(?). what do you guys think?
Old 07-08-2005, 09:48 AM
Mrwood's Avatar
Last journal entry: My 1962 Falcon
is this bad
Replace it, you will have problems later. Its not worth the chance you are taking, so replace now.
Old 07-09-2005, 10:11 PM
77z's Avatar
77z 77z is offline
Go big or go home
Ditto Better to be safe then back in then same boat in a few weeks / months with it apart again
Regards Mike
77 Z28 496 9 inch
10.23 @ 129
Bad Oil Leak,,, Help! Lthompson Engine 8 08-15-2007 03:33 PM
Bad jokes Wmarden Hotrodders' Lounge 28 10-14-2004 06:37 AM
My Report: ITS BAD. VERY BAD. Native Gearhead Transmission - Rearend 12 09-21-2004 10:30 AM
how bad is it to ride on bad akm Suspension - Brakes - Steering 5 05-13-2003 09:28 PM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 04:43 PM
