I recently did a complete air ride system in my 66 Impala. The kit was purchased from Air Ride Tech.
The kit has a ECU that controls the air pressure and also controls the air valves. My passenger front air valve keeps shorting out. The valve will deflate but not inflate.
From the ECU are weather pak connectors that connect to the air valves. I checked the power coming from the ECU that goes to the passenger front valve and have power when I hit the button for inflate. I have also checked the weather pak connector at the valve and have power. Both ends have power when I hit the inflate button.
Air Ride Tech has sent me 3 new air valve and each one worked for a day and then goes out. I realize there probablly is not enough information here for you to help diaganose this problem. But I figured someone might have experience something like this with a air ride setup...
I have double checked the wiring directions and have everything wired correctly. The air valves get their power from the ECU unit and no where else. And the air valve ground to the frame.
I sent my system back to Air Ride Tech and they said everything worked fine. They sent it back to me and it did not work. My car has all new wiring. And no other electrical component has any issues. Air Ride Tech has never had this problem. What is strange to me is that the same air valve goes out each time. So that make me think the ECU is bad. Hopefully someone can shed some light on this subject..... thanks......
And please ask questions if you need more info...... :thumbup:
