Bad BF goodrich tires!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2005, 04:54 PM
I recently purchased some BF goodrich radial T/A tires, and im now having problems with them, Two of them have developed bulges in the sidewall!! one only has about 1000 miles on it , and the other only has about 300 miles on it. What causes bulging in the sidewalls? and has anyone else had any problems with this? thanks for any help.
Lance
Old 04-08-2005, 07:05 PM
broncoII88's Avatar
Do the right thing...
Where do you live? If you live on the equator than that might be heat distortion, but it's most likely a manufacturing defect. You MAY be able to return them for new ones. I say may because some stores are really fussy about returns. Especially if the item is worn. Then again, they might be concerned for safety reasons. Then you might get two new tires.
Old 04-08-2005, 08:14 PM
I live in Oklahoma U.S. and it is just now spring, so i doubt its heat distortion, I ordered the tires through Jegs Performance. the are 295/50 SR15 radial T/A tires. I just think it is really strange to be having 2 tires with bulging sidewalls after just 500 to 1000 miles. I sure hope i can get them replaced, or im going to be EXTREMELY mad.
Old 04-09-2005, 12:45 AM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Lance,
I would contact Jeg's and explain the problem. They will probably replace them. I have been running TA's for the past 2 years without a problem.
Bob
Old 04-12-2005, 07:35 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Originally Posted by AngliaBob
Lance,
Bob
I have only heard good things about those tires until today, I agree with AngilaBob.
Old 04-12-2005, 10:07 PM
CaptMysterio's Avatar
i've run these tires ever since i could drive with not so much as a flat. first time i've heard about defects in these tires as well.
Old 04-12-2005, 10:42 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
do they have bubles or a slight indentation where they are seamed toghther are they running out of balance or trueness?
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 04-14-2005, 05:20 PM
I had them mounted and balanced on brand new wheels. One tire has a large bubble about 4 inches by 4 inches protruding out the side, even causing the white letters to be stretched and such. THe other tire just has a small one starting to stick out. But i guarantee they are bubbles.
Old 04-14-2005, 05:21 PM
I had them mounted and balanced on brand new wheels. One tire has a large bubble about 4 inches by 4 inches protruding out the side, even causing the white letters to be stretched and such. THe other tire just has a small one starting to stick out. But i guarantee they are bubbles. Im going to have them inspected tomorrow to see what the deal is, BF goodrich told me that if they are defective, i can have them replaced at any dealer.
A really bad day with a car :/ Please help if ya can esears Hotrodders' Lounge 7 08-30-2005 10:16 AM
I need my bad luck to go away..... onebadmerc Hotrodders' Lounge 5 01-23-2004 09:08 PM
is this repetitive bad luck or what? 71gtx Engine 4 11-18-2003 08:19 PM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
Bigger tires Speed-o-meter is off CompFX Transmission - Rearend 9 10-18-2002 12:56 PM
