Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bad body work /cars with hidden surprises
  #32 (permalink)
Old 12-07-2012, 01:40 PM
gearheadslife gearheadslife is offline
Banned
Originally Posted by tech69 View Post
from experience, I'd say we were all hacks at one point. There seems to be an order of skills obtained and often times you will be a hack until someone points it out and you learn from it. Thick edges of filler is one thing. If you have a big dent and you know your filler is gonna go to the edge you gotta use a straight edge or something to indicate if there's metal work to be done to eliminate thick filler on edges. A straight edge nearly eliminates this problem. Another thing for me was pin holes. In a crunch, instead of wiping it down hard I would fill AND try to wipe it down hard to straighten and also leave me no pinholes. This just led to trouble. Always better to get it done and throw on more tight coat, and even the mixing and flattening it out will help with this. Now, I don't even need a poly glaze or top coating filler, I can get pinhole free work with good fillers. Another example is knowing where to skimp on the cheapie jobs. On this superbee we're doing the boss had a look at the dull yellow paint and thought it would be minimal spot filling. Turns out the color is deceptive and it needed more work. The decklid needed a lot of work and so instead of being patient and working the thing thru I stopped and made a judgement call. Turns out, after prime, I just spent 30 more minutes on it and it was a done deal. I should have just dealt with it the first time around. This was also a learning experience to know WHERE to cut corners and where not to. So for that job I can now safely say that the decklid and hood are looking good but thank god that reflective yellow paint will hide some imperfections down low, as I've learned THIS is where you'll be making shortcuts if called for. with that said, it's also a place where lazy older techs seem to miss stuff, even on the higher end jobs. Just trying to give reasoning behind some of the hacking you see from a tech's standpoint.
and this is the down side of a flatrate shop working on anything other than latemodel wrecks
