Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bad body work /cars with hidden surprises
  #44 (permalink)
Old 12-09-2012, 01:10 PM
TucsonJay's Avatar
TucsonJay TucsonJay is offline
I've probably told this story in another thread, but...
An old customer brought me a 1968 AMX. He wanted to paint it in an updated version of the factory race cars of that era.
The car had been done on a rotisserie during the last restoration. What was obvious to me was the clear was peeling away from the metallic blue basecoat... showing me that they did not understand the adhesion basics for urethanes. No problem! I stripped the clear in one day using an air gun and razor blade!
Before I did that, I had seen some "dust or dirt" in the clearcoat. As the clear came off, I noticed the bumps were actually in the basecoat. I told him I would block it good... and then go to primer next.
When I blocked them... each bump was full of rust! At that point I told him we needed to strip the paint, because the rust obviously would ruin the next paint job too! Obviously the last shop... WHICH WAS IN FLORIDA!!!!!!... did not understand basic urethane paint principles OR "basic rust prevention 101"... either!!!
As the paint was coming off, I could see that this car had bodywork from top to bottom! It continued even futher! After the paint was off, I could see rust nibs under the bodywork! Of course that meant digging out a gallon or more of filler!!!
Under that was a nice selection of patch panels.... and we found some OTHER places that needed further repair work!
In the end we took it all the way back up, adding a factory Super Stock hood scoop, and some additional art on top of the red-white-blue factory race paint.
Today it should be good for 20 years or more... but it was a lengthy task!!!
ID:	69678   Click image for larger version
ID:	69679   Click image for larger version
ID:	69680   Click image for larger version
