Bad bondo job??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-27-2006, 05:07 PM
With a bit of experience you will be able to spread a fairly large area neatly knowing what areas are going to need the most fill, and about the amount of filler you need to mix and how thick you need to apply, Hit it with a 8 inch orbital with 36 grit followed by using a straight line sander and sanding blocks and have it straight and knocked out fairly quickly without many applications of filler. Keep practicing and hang in there. If you have a really large area to do, a drywall spreader may help you get the bodyfiller slapped on and spread smooth quicker. In areas where the filler will need to be feathered in, go and spread the edge thin so you don't have a big ridge of filler and make it easier to feather in when it comes time to sand.
  #17 (permalink)
Old 01-30-2006, 10:42 PM
Back when I was a senior in high school, my afterschool job was as a gopher at a major car dealerships body shop...this was back in '87. I remember the guys using those long board air sanders...very neat tool. I also remember the day the guy came out to demo a plasma cutter... HUGE dollars back then, but I was impressed! I'm wishing like hell now I had stuck around those guys when I had free time to learn... back then all I was interested in was HP! Hindsight is 20/20!!
Ron
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 12:19 PM
Run in Clear at a bad spot.. what to do?? Z-Money Pit Body - Exterior 6 06-21-2005 02:53 PM
My Report: ITS BAD. VERY BAD. Native Gearhead Transmission - Rearend 12 09-21-2004 11:30 AM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 09:02 PM
bondo removal question broncoman Body - Exterior 3 06-22-2003 02:16 AM
