Bad bondo job??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2006, 01:38 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Bad bondo job???
OK. I've read many posts, I follow directions, and it still looks like s....
My bondo just won't smooth out. I end up with little valleys or humps. I sand off the humps, fill in the valleys, and end up with new humps and valleys.
I used 7 pounds of Bondo, must have 6 pounds of dust on the floor. Can anyone guess what I'm doing wrong?
Anyone make housecalls?
Old 01-26-2006, 01:50 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
What kind of sanding block you using?
You need a long straight hard one. (sanding block that is)
Old 01-26-2006, 04:15 PM
roger1's Avatar
Sand it with a hard backed board by hand like Jim says. Buy your board and the paper for it at your body shop supply store. (Pep Boy's doesn't carry the stuff you need.)
Start out with 60 grit. Fill any remaining low spots and sand with 120 on your same board. Finish off with 320 and then spray on your surfacer. Then fill any pin holes with spot putty (not the air dry junk) before your second coat of surfacer.
Sould be a fairly quick process if you doing it right.
You will want to use a long hard backed board for sanding your primer/surfacer also. I like to start out with 180 dry and finish with 400 before any follow up coats.
Old 01-26-2006, 04:53 PM
milo's Avatar
point on positive
Have you ever seen these pictures before? ... ...
If not click this for a sec http://www.a2zautoforums.com/showthread.php?t=936
ID:	9543   Click image for larger version
ID:	9544   Click image for larger version
ID:	9545   Click image for larger version
ID:	9546   Click image for larger version
Old 01-26-2006, 05:17 PM
what grit are you starting out with? If its a pretty large area with a bit of fill to be done, I find it easiest to get straight by starting out with 36 grit on as long of a block as possible in the area you are working, unless of course the block is a lot bigger then the area you have to do. Once its straight then worry about taking care of scratches by going over with a finer grit, or applying a skim coat of filler over the whole area and block sand that with a finer grit. Sand from one end of the filler to the other end in an x patterns if possible until it feathers out. You need to have the feel to determine what areas are high and need more blocking and what areas are low that need more bodyfiller. Applying some 3m dry guide coat or misting some rattle can black over the filler before sanding may help someone without much experience some and help identify low areas, but you still need to have a feel when its sanded the right amount and which areas to concentrate on that need more work. Get the filler sanded down to 80 or 180 grit scratch and straight before your first round of primer, Then block sand that primer with 180 grit, and if it feels good at that point, spray a few more coats of primer and sand that with the final grit recommended for the paint you are using. If not, more rounds of block sanding and priming, or even possibly finishing putty. If its still not straight, then you need to get the body filler straighter before thinking of priming.
Old 01-26-2006, 05:22 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
Thats your answer
anytime you add a new coat of filler in just one spot, it will become a highspot
anytime your adding filler, recoat a larger area, dont just try to fill the lows
Old 01-26-2006, 06:28 PM
oldguy829's Avatar
Wiki Edits: 88
Bad Bond
Thanks to everyone. Milo, that tutorial is excellent. I may have found a clue. 1. Waited too long to sand, so its rock hard and lots of work
2. started with 100 grit instead of 36
3 used 4 " sanding blocks instead of long blocks
4 tried to "spot" in the lows instead of covering the entire thing again
Other than that, why am I haveing trouble....LOL>
Old 01-26-2006, 07:14 PM
jim..'s Avatar
That 6 Cylinder Guy
OK. I used 7 pounds of Bondo, must have 6 pounds of dust on the floor. Can anyone guess what I'm doing wrong?
Man,I laughed so hard at that !!!!
That's exactly what I did when chopping my truck,finally gave up and took it to a body shop to have the finishing work done,since then I've bought all kinds of body work tools,sanders,feather edgers,sanding blocks of all size and shapes,but that finishing work still eludes me.
I have a greater respect for the body guys that can do suh a nice job,they make it look so easy.
I hope you figure it out,if not, let the pro's do it,otherwise you will never be happy with it.
I'm putting a new hood scoop on my truck next week,but I'm having it done by a pro,I just don't have the nack for it.
7 pounds of bondo and six pounds of dust.
Old 01-26-2006, 07:57 PM
Yeah, I too like to catch the filler when it is still a little soft, makes shaping it so much easier. If you just have a few low spot in the filler, catching it while it is still soft makes things easier too, that way the filler you just put on sands easier then the already existing filler, and you don't end up cutting down as much on the filler you already had on that getting it smooth and level. There is times when I like to let my filler set up, if its too soft it can tear and not feather as nice, but initial shaping I like to do while its still soft, unless its only a small dent or something, then can let it set up and start with 80. Once all low spots are filled and it all feels straight, I often will put one thin coat over the whole thing and sand with 80 grit and then take some of the 80 grit scratches out by going over with 180. A finishing type filler works well for a thin coat over the whole thing if you don't really have any big imperfections or low spots. The finishing puttys spread smoothly and seem to sand easier. The skim coat of finishing putty I will let set up a bit.
Get enough practice working with bodyfiller or any bodywork and paint for that matter, and you pick up your own favorite tricks that work well for you, to get good results faster. I am sure a lot of people have experienced troubles and a lot of bodyfiller, sandpaper, and muscle
wasted starting out. Its kinda funny to watch someone who doesn't have any real experience working with filler in a bodyshop sometimes, but eventually get taught the tricks from others in the shop, hopefully at least. I've seen guys before work on a small dent, fill it, sand to much off, fill again, and over and over.
Old 01-27-2006, 09:48 AM
oldguy829's Avatar
Wiki Edits: 88
bad bondo
It is kind of funny, as in pathetic. But I'm going to try again. Just have one concern. What I am filling is where the top was welded in, so the idea of always doing "the entire repair" is not possible. I can't mix a batch big enough to go all the way around the top in one pass.
Any tips for handling this situation?
Old 01-27-2006, 10:29 AM
milo's Avatar
point on positive
Good for ya! Now that your thinking has changed and you have a better understanding of why filler sands at different rates your in a better position to control what is going on. Maybe work it into halves or thirds etc.. Use the end of a curve or crown line...
Heres a monster of a car yet it was done in sections.
http://www.a2zautoforums.com/showthr...6&page=1&pp=10
The fillers can also be thined with the resin or "honey" and making them cure a little slower as well as handle larger areas.
Hang in there!
Old 01-27-2006, 11:35 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
ok read through and adding my $.02.
by chance how much hardner are you using? also what is your setup time? body filler has a working time, and when you mix up larger ammounts, and use more hardner, that time decreases... from past experience, about 1" line of the hardner cream to a about a pingpong sized ball of filler works. but sometimes i use more filler. mix it up fast to make sure the color is consistend, then apply using a plastic body spatula. i normally try to lay it smooth as possible to help when having to cut it down. and i too start cutting when it is a little tacky too... i use a body file, looks like a cheese grader to sut down the ridges and thick spots. as for the spot putty filler creams, i tend to not use that. i use a high fill primer and block it out to get rid of the pin holes and small gouges/ lines.
hope this helps, JS
Old 01-27-2006, 12:10 PM
ronnied's Avatar
Last journal entry: 49 Ford
Get Local Help
Its truly an art to shape with fillers. I suggest trying to find a local body shop and buddy up with one of their body men(a six pack will do). When working with fillers start with the roughest file paper, 36 grit on an air file or long board file. When sanding, dont sand up and down or back and forth.. Sand at an angle, say from lower left corner to upper right and reverse this. That is like cross hatching. This is where your new buddy comes in handy as he will be happy to show you. I only finish my fillers with 80 grit and then prime with three heavy coats. I then lightly spray a coat of black spray paint over that surface and hand block starting with 80 grit. Thats called guide coating and will help you find low and high spots. One thing many beginners do is overwork the surface. If you keep hitting metal, back off and add more filler. Get a three foot steel straight edge and make sure your metal is semi straight to begin with.
Old 01-27-2006, 12:20 PM
jvsapp's Avatar
good point on the guide coat. same with the cross hatch sanding. i remember a hotrod body work magazine that came out a few months back. covered everything from rust repair to buffing. i was wondering though. am i the only one that has heard of the body file? does any one else use it? when the body filler is still soft, it cuts it down really fast... and it is reusable unlike 36 grit paper.
Old 01-27-2006, 12:36 PM
jcclark's Avatar
The Penny Pincher
I still use a body file, but only for the first "shaping"
just to get it close to size.
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 12:19 PM
Run in Clear at a bad spot.. what to do?? Z-Money Pit Body - Exterior 6 06-21-2005 02:53 PM
My Report: ITS BAD. VERY BAD. Native Gearhead Transmission - Rearend 12 09-21-2004 11:30 AM
How long does it take thin amounts of bondo to crack? stonedchihuahua Body - Exterior 14 07-12-2003 09:02 PM
bondo removal question broncoman Body - Exterior 3 06-22-2003 02:16 AM
