Bad day and night - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2004, 08:57 PM
western star's Avatar
Bad day and night
Gee it must me my turn for a bad day. First I locked the keys in my car at work, then a bad day at work then I figured I go out for a ride in the rod and I run out of gas in the middle of a busy intersection. This gauge and sender is made by Classic Instuments. It's always been right on for reading accurate. It says 1/4 tank and it was bone dry. What is the correct way to test if the sender is screwing up or the gauge is faulty. I could use the 1/4 mark as empty but I like things to work properly. Thanks
Old 10-21-2004, 03:56 PM
Tazz
Look at the bright side..NO FIRE...right?? That should make you smile!! There is a possibility that the tank still has gas in it and can't be picked up the way you have the tank mounted...CK the tank for level/square!! Side to side and back and forward like a big box!!
Tazz
Rat Rods Rule!
