Bad Drive shaft vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2010, 07:02 PM
I have Pulled the drive shaft and measured the Yoke and Tail shaft Bushing In my TH 400 Trans.
Yoke to Tail shaft bushing clearnce Question?
Yoke is 1.885 Bushing is 1.894
That .009 clearance.
I'm Not an expert on trans but this seam like .007 too much.
Note: Trans was justrebuilt and my Pro Street has a New drive shaft that was balanced.
Thanks for any help on this.
Old 08-23-2010, 07:19 PM
LATECH's Avatar
009 thousanths wouldnt concern me. Sounds more like a driveshaft out of balance or the crosses are not in phase. was the shaft cut/ shortened/ fabricated new???
Old 08-23-2010, 07:22 PM
Drive Shaft was Fab New
Old 08-23-2010, 07:30 PM
LATECH's Avatar
If you are sure that the vibration is from the driveshaft then check to see if a mistake was made when it the yokes were phased properly and then welded on (the yokes are perfectly in line from end to end.)If they are not phased the velocity change in the shaft from end to end wont be the same and it will vibrate like crazy. Maybe pull it and get the balance re checked.
Old 08-23-2010, 08:01 PM
Thanks,
Since it is out and the Drive shaft shop is only a block way from were I work I was planning on dropping it off to have it check. The Shop has been in Busness for 30 year and I have had work done by them before with no problem.
Note:
The Shaft yokes look Like they are in line.
Could this be the Main Bearing or bushing in the out put drive shaft of the trans, if I rule out the Shaft tomorrow. Motor is a 383 525 HP 3200 Stall converter. I run a Ford 9" with 4:56 gears and a Spool. Could I have broke something in side it? Motor and Trans only have 462 mile on them.
Old 08-23-2010, 08:22 PM
LATECH's Avatar
I dont think 9 thou would be an issue. Could maybe a few needle bearings got lost from one of the caps? Anyway have the shaft double checked.anything else escapes me at the moment. Ill probably wake up about three or four tomorrow morning and have the answer. LOL
Old 08-23-2010, 08:39 PM
ericnova72's Avatar
More for Less Racer
Factory yoke on the 9"?? I have seen factory yokes machined quite far out of concentric with the splines, doesn't show its head with 2.75 gears, but when driveshaft speed is doubled with something like 4.11 or 4.56 then a driveline vibration shows up. Use a dial indicator and take a run-out check at both ends of the installed shaft and let us know what installed run-out is.
Old 08-23-2010, 09:04 PM
LATECH's Avatar
Now that you mention it I remember hearing something about that a while back. It makes such perfect sense too. Something I clearly did not consider.Nor did I remember ( CRS) untill you mentioned it . That is fast to check out also.
Old 08-24-2010, 06:50 PM
Thanks, For the help.
The drive shaft checked OK. Installed it and used a dial indacator on the Trans yoke and found .025 run out. Rear Yoke was OK.
Well with 589 Foot pounds of torque 18.5 wide tires something has to bend.
I have detremined with your help that I have a bent trans out put shaft.
Time to up grade. Any Ideas?
Old 08-24-2010, 07:30 PM
ericnova72's Avatar
More for Less Racer
I'd be looking at something else, a trans tailshaft will be very hard to bend, just power won't do it, it would need to be in a collision. It may just be the yoke.
The .025" on the runout, is that total indicator movement or .025" on the radius?? .025" total is not that far out, I would be looking at driveline angle differences between trans and rear axle.
bad vibration at 60-70+ NovaGuy80 Engine 8 06-10-2010 12:12 AM
9 inch & Drive Shaft Swap Morgan22 Transmission - Rearend 2 06-21-2008 03:30 PM
Bad vibration in 700R4 or the driveshaft?? Overdriv Transmission - Rearend 5 12-01-2007 03:10 PM
Drive Shaft Length 71 c-10 Suspension - Brakes - Steering 7 10-25-2007 02:53 AM
drive shaft removal stu_yoakam Transmission - Rearend 13 04-02-2007 03:01 AM
