bad frame, time to build a new one - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 11:17 PM
dodge it's Avatar
Last journal entry: yep
started channeling my '36 dodge and found the frame is rusted real bad in a few spots , so i'll be building a new one and have a few questions
1. what size and thickness of tubing ?
2.any other tips ?
Old 12-19-2010, 01:23 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I used 0.120 wall and made the depth to match the existing chassis..you can taper the ends to make it look good..
Sam
Old 12-19-2010, 09:09 PM
dodge it's Avatar
hey
thanks for the tip .
the existing frame is 4'' in the front tapers up to 5'' in the center and tapers down to 3'' over the rear axle.
so i was thinking of doing 4''x2''
Old 12-19-2010, 09:22 PM
I have to ask, is this frame REALLY rusted too bad to save? Many times frames will have some severe rust in a rust prone area and the rest of it is still good. It may be "rusted" but it isn't too bad other than a few spots. Just how bad is the frame?
Old 12-19-2010, 09:23 PM
life is a temporary assignment
Should work fine..
Old 12-20-2010, 12:29 PM
dodge it's Avatar
hey
yep the frame is done i can push a screwdriver through it in several spots and the rest of it is full of dirt end rocks so i'm sure it held moister in those spots .
thanks for the foward thats a good lookin frame .
Old 12-20-2010, 12:32 PM
Build one, And don't look back..
Old 12-29-2010, 08:37 PM
Last frame I built was out of 4130 seamless steel tubing, 5/8" OD, with .035 wall thickness. the finished product weighed about 1100 pounds complete with 150 hp engine. It would carry 40 gallons of gas, and 760 pounds of people and stuff, at about 145mph. and get around 20mpg.
Oh, nevermind, wrong forum.
Old 12-29-2010, 11:50 PM
1971BB427's Avatar
2"x3" or 2"x4" box tubing, with .125" thickness is pretty std. for a frame. No reason it needs to be different size for different parts, other than narrowing it at the front for asthetics.
Time to build a killer small block, but have questions? GasCan Engine 12 11-15-2011 08:43 AM
32 Chevy build looking for a frame ekwoodard Body - Exterior 4 07-21-2010 09:30 AM
New member want to build my own frame John CV64 General Rodding Tech 6 04-23-2010 11:56 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Gen V 454 good or bad to build? Hacksaw Engine 1 04-18-2009 06:04 PM
