does not sound normal to me, never seen one loose inside. but it is normal for alot of fuel to come out when you remove it. your system pressure should be around 45lbs.happy motoring steve.
You should be able to blow air thru the filter with little or no restriction. Gas should come out of the filter when you take it off the car. It doesnt have a check valve. If you suspect its contaminated, bang that thing on a bench (inlet fitting) and see if anything comes out of the inlet side. Cut the filter open and see whats inside if you suspect something loose. Arnt you curious whats inside?
In my area it seems, changing my fuel filter has be come almost routine and predictably once a year, when it clogs up and the moto no go no mo. Yep, gas always comes out both ends, but you can't blow air through it. But a new filter should have very little, if any restriction.
And yes, cut that thing open. Inquiring minds want to know! [ March 14, 2003: Message edited by: Busted Knuckles ]</p> |
