If the pump isnt old I would suspect that there is a problem in the fuel line from the tank. Check to see if there is fuel being drawn up through the line. I have seen where on older vehicles, the fuel line rusts out on top of the fuel tank......The pump then just sucks air....or very little fuel. Worth looking at.
Ontario Rodders |
well the pump is ok its the fuel pump push rod. it is stuck in the block it wont come out all the way. so that means the top of the push rod is mushroomed!!! how do i get it out???
Can't pull it out with vise grips?....Only other way is to remove the cam, push it up so you can grind the mushroomed part off. Then you need to find out why it got that way....Lack of lubrication?
Ontario Rodders |
| Help - my fuel pump is leaking | KENMO | Engine | 10 | 07-01-2007 12:39 PM |
| HELP QUICK Electric Fuel Pump Leaking | 66 T-Bird | Engine | 4 | 06-06-2005 06:26 AM |
| Which waterpump? | Eagle1 | Engine | 5 | 08-06-2004 06:38 PM |
| Bad fuel pump??? | ffcagle34 | Engine | 2 | 06-20-2004 11:15 PM |
| Lean backfire | Camaro76 | Engine | 5 | 04-15-2003 05:45 PM |
