Bad fuel pump??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2004, 09:49 PM
Bad fuel pump???
You guys are awesome. I have a new problem though. 350 sbc with roch. 4 bbl carb. Engine runs for 2-3 minutes then dies. No fuel in visible fuel filter. Wait 5-10 minutes and engine fires up strong then dies after 2-3 minutes and fuel filter is dry again. Mechanical fuel pump.
Will a bad fuel pump work off and on again or is it another problem. Thanks
Old 06-20-2004, 11:05 PM
DoubleVision's Avatar
If your fuel pump has a return line, try this test, take a pair of vice grips and kink shut the return line, if the pump works fine then the pump is bad.
Old 06-20-2004, 11:15 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Yep a failing pump can act that way. Also the filter sock in the tank could be stoped up.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
