Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bad or good: engine break-in
Old 02-01-2005, 10:02 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
If your break in lube (cam) was a moly type paste. It will end up on the bottom of the pan. It won't hurt anything. The rear seal problem is unfortunate. Did you install it with the major lip forward, stagger the ends and use silicone sealer?
