Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bad or good: engine break-in
Old 02-01-2005, 10:21 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
I have never seen the red lube leave a deposit. Usually the grey paste type lube. Rear seal leaks are not uncommon on small blocks. That's why they changed to the one piece type seal. Did you put sealer on the rear main cap/block mating surface.? If not oil will weep thru and look like a rear seal leak.
