Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bad Ignition Coil?
Old 01-08-2013, 04:46 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Coil is def a suspect....... also check your dizzy cap and rotor for a hairline crack. I had one that had a hairline crack, it was an after market etc..... when it heated up it would start cross firing and stumble and die..... ended up replaceing them both and the problem went away.
