Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bad Ignition Coil?
Old 01-26-2013, 06:50 PM
kaoticmustang kaoticmustang is offline
Just a quick update, I have changed the coil, condenser, cap, and voltage regulator. I was getting about 16 volts at the battery with it idling until I replaced the regulator. I will be double checking everything tomorrow as it is still doing only much sooner now. When it dies I am still getting voltage to the coil. There are 3 fuel filters on the car so I will check those as well. Thanks for all the help and suggestions. I will give an update soon.
