bad lifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2005, 03:39 PM
Matts99Sierra's Avatar
bad lifter
i just tore apart my 350 chevy and checked for what was thought to be a collapsed lifter. i pulled a lifter out and the bottom where it hits the cam was worn down and cupped. all the rest of them look fine. any ideas on why this happened? a stuck lifter? will it be ok to replace just 1 or do i have to replace them all. oh, and its a hydraulic lifter setup. thanks ahead andi appreciate the info.
Old 03-02-2005, 03:44 PM
johnsongrass1's Avatar
Race it, Don't rice it!
flat cam lobe.
Rockwell hardness problem
QC tech
Plugged oil passage.
Could be a number of things.
How many miles?
Old 03-02-2005, 03:50 PM
i got the motor with just under 500 miles on it... it probably has about close to 1000 now.
Old 03-03-2005, 10:33 AM
cuda66273's Avatar
Are there one direction grooves in it or is it nicely rounded out all the way around?
Old 03-03-2005, 10:38 AM
Siggy_Freud's Avatar
You could replace the 1 and risk it being the problem. Or, with it being torn down half way already you could put in a new cam and new set of lifters and play it a bit more safe. Might just pull the cam to inspect if and if it looks good toss it back in.
Old 03-03-2005, 10:46 AM
Sorry added this in in wrong post.
Old 03-03-2005, 12:49 PM
rounded
its rounded out all the way around... theres no directional grove to it. oh and i pulled the rest of the lifters and they were ALL the same way except for 1. there was only 1 good lifter and rod in the whole engine.
Old 03-03-2005, 12:55 PM
They should all be somewhat rounded as they spin in their bore as the engine runs.
Old 03-03-2005, 01:57 PM
DoubleVision's Avatar
Your likely going to have to replace the cam. You could replace the lifters, but the problem will repeat itself. My neighbor just went through this same thing, he had pulled the intake twice to replace 1 lifter that kept cupping, he called and asked what the problem was and I said "replace the cam" he pulled the cam and saw the lobe was almost gone.
If your having problems with such low miles it sounds as if the cam wasn`t broken in properly. After doing the cam swap and breaking in the new one, I would add a can of sea foam to help clean the trash out of the oil galleries, since it`s likely now that it`s worn down the lifter, after the break in, pour the sea foam in, run it 20 minutes at idle, then change the oil and filter. This also happens alot to engines that sit a while, I`ve seen many a small block chevy do this when it sat.
Old 03-03-2005, 04:00 PM
Flat cams suck
Yup, the cam is junk and the lifters are junk. The face of the camshaft will look worse than the lifters. If you can pull the motor and tear it down for a proper cleaning and inspection that would be best. Sticking a new cam and lifters in without tearing down is a risk, due to the debris floating around. Bottom line though is if there is damage to bearings and cylinder walls it's already occurred. Just keep an eye on the oil pressure. When you do install the new cam and lifters make sure to use assembly lube on the cam and face of the lifters, lots of it. Also give each lifter a reality check as to fit and ease of rotation in the bore. Make sure it is a tight fit but not binding. It is also mandatory that you prelube the motors oiling system prior to firing the first time. Be sure to follow the camshaft manufacturers' specs for break-in springs as well, if needed. Also, once you take the cam out if you can bend over and inspect the camshaft bearings for any marks or wear that would be worth some piece of mind.
Most important, make sure everything is timed correctly so as the motor fires right away and keep the RPM above 2000, in the 2500 range is where keep it, for at least 20 minutes. We also add a can of GM Engine Oil Supplement for break-in. It is loaded with zinc, which is an excellent high pressure lube. After break-in change the filter and cut it open. If you have a problem it will show up in the pleats of the filter. Also run back through lash while the engine is burn your fingers hot still and lash to spec, assuming a solid flat tappet cam. When the motor cools to ice cold recheck lash and now you have the proper spec to set them cold.
There are a ton of reasons for the camshaft failure, improper break-in is one. Of late though with the shakeup in the lifter industry camshaft failure on small block Chevys are high. The indexing of the lifter bores is much more critical it seems these days in it's relationship to the lifter and camshaft taper position on the lobe. If things are off lifters may not spin properly and eat a cam within minutes. Sometimes it just happens for no apparent reason and you stick a new cam and lifters in and viola, not a problem. One of these days I'll share the work the shop went through on camshaft failure and the things we found out working through the issue with Dema at Elgin Cams.
Old 03-03-2005, 04:02 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
That's alot of metal shavings to send through an engine.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Spun bearing or bad lifter? He drove it 25 miles home elukas Engine 7 06-22-2004 06:27 PM
Fractured lifter slvrbllt Engine 9 04-30-2004 08:13 PM
bad lifter? 88 olds Engine 2 12-23-2003 04:19 PM
bad hydraulic lifter? KeithB123 Engine 2 09-28-2003 12:42 PM
