Bad Motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2009, 07:38 PM
Bad Motor
need some advice on flushing a motor with 70,000 miles.Is it wise to use diesel fuel as a engine flush. Mechanic flushed motor and now i have several collapsed lifters. He told me it was the same as what you buy in stores but he dumped a gallon of diesel fuel into my engine. Need some input on this matter
Old 08-19-2009, 08:29 PM
Hydraulic lifters have the smallest oil passages in the motor, by flushing the motor, he broke loose some grime that has now lodged in a lifter oil feed, plugging it off, and causing it to collapse.
If its a service he sold to you, tell him to fix it.
Old 08-19-2009, 09:01 PM
The mobile view is crap
GUNK sells a quart of what they call "motor flush" which is basically 1 quart of really clean diesel fuel that they sell for 4.50 a quart. You really should flush your engine every other oil change
Old 08-19-2009, 09:16 PM
MI2600's Avatar
Member# 3287
[QUOTE= You really should flush your engine every other oil change[/QUOTE]
I think I'd have to see where that's recommended!
Old 08-20-2009, 11:19 AM
DoubleVision's Avatar
Pour in a can of seafoam and start the engine. Let it run 20 minutes then change the oil and filter.
Old 08-20-2009, 02:01 PM
I think it's printed right on the can of motor flush...
Old 08-20-2009, 02:15 PM
Of course the people that make the product want you to use it at every oil change!!!!
Old 08-20-2009, 03:55 PM
You read on my post where it was recommended to do it.
Old 08-20-2009, 04:24 PM
SSedan64's Avatar
Dumped a gallon of diesel fuel in the engine??
A quart yes, but a gallon?? I hope he had some oil with it.
Old 08-20-2009, 04:39 PM
wow!, I didn't even realize you said a gallon of diesel fuel. That is a lot of fuel. If he dumped that much fuel in your engine and let it run like that you need to go kick him in the sack and graffiti his building if he won't fix it.
Putting a Grand National Motor in a Cutlass ChrisMiddleron Engine 8 04-01-2011 08:54 PM
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
Is idling new motor bad? bigolblackie Engine 9 03-14-2006 03:41 AM
emision loopholes digitalfrek Engine 13 03-13-2006 06:25 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 01:26 PM
