Bad relay? need some help testing - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-06-2010, 06:59 AM
bubbahotep's Avatar
EOD, lol, you're confusing me now.
I meant the little relay he remove has a bad coil, not the ign coil. I think the reason the ign coil reads short to gnd is because it shares the same power feed. Like, if you took the (+) wire off the car battery abd pressed it to chasis....every item in the car would read as shorted too. His relay coil (guessing) is shorted and it's also making the ign coil appear that it gies the gnd.
The reason I don't think it's the contacts in the relay is because they're normally open with no other "normally closed" contacts. Even if they welded together they'd only "turn on" a particular circuit prematurely.
  #17 (permalink)
Old 11-06-2010, 10:46 AM
EOD Guy's Avatar
tried to upload a tif of a 78 wire dia.... didn't work wrong file ext. In it it shows that the fuel pump is tied to a altimeter switch etc........ send me a PM with your email and I'll send it to ya
  #18 (permalink)
Old 11-06-2010, 06:44 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by garretthes
I understand how a relay works. However it shows a short to ground without power. I have the ignition off and the battery disconnected. I have a test lead connected to the + coil wire and the other end to ground. When I plug in this EFI relay the +coil wire grounds out. When I unplug it-no ground.
Am I doing this wrong?
If they fall apart inside it could cause a short between any two or more pins, I have seen this happen a few times.
Chet
1980 TA choke relay jdcoic Electrical 17 05-16-2013 07:09 PM
NSS Relay problem Javelin360 Electrical 1 04-19-2008 03:14 PM
Ford relay ratings? oldred Electrical 16 07-30-2007 07:05 PM
Help Wiring A Relay to A Dash Switch horvath Electrical 6 03-06-2005 01:58 PM
Omg, Car Fire!! Malibu1980 Electrical 21 06-16-2004 12:34 PM
