Start the engine at night and look at the engine, sometimes you can see the spark leaving the wires if they are bad. The other way which I usually use if no spark is visible is use an ohmmeter on the wires to check for continuity and ohm value.
I'd replace the wires, anytime wires are "mushy" I question how much spark energy is being lost. They are cheap enough.... Did you gap the plugs? Once this is checked out, get the timing light out and set the dist timing again if you moved it around. Good Luck |
| Spark Plug Wire Size | derekg383 | Engine | 1 | 11-20-2008 12:00 PM |
| Spark plug wire protection | kruzr | Engine | 6 | 11-08-2007 05:56 PM |
| spark plug wire lengths | robman909090 | Engine | 8 | 05-12-2004 10:07 AM |
| How do these spark plug wire Ohm checks look? | crazie | Electrical | 2 | 03-15-2004 06:20 PM |
| Spark plug wire spacers | Jag Daddy | Engine | 3 | 06-02-2003 05:36 AM |
