no pro here but I've sprayed tons of paint
Like said above. Two medium wet coats. NEVER dust coat or build up to a final flow coat. If you're reducer is matched accordingly to the temp your spraying in, you can flow this stuff pretty heavy on your first coat without running or sagging. Even over a 400grit surface.
