-   -   Bad Struggle with Nason SS (http://www.hotrodders.com/forum/bad-struggle-nason-ss-199882.html)
Paintdian 06-05-2011 07:03 PM
Hello guys. :welcome: I have come here with hopes of seeking different opinions for a newbie painter. I have zero experience with automotive paint finishes although a house painter by trade. What I am doing it restoreing a pop up trailer and have done the body work and blocked down the 2K filler ready for paint.
The deepfreeze is what I am spraying to get to know how to use this paint. I have had nothing but bad luck here.
Ive read many things over the nett and watched videos but the thought of doing this is alot easier then actually doing it. Ive sprayed this deepfreeze four times now and it isn't getting to where id like to see it.
The paint is some new environmental Nason SS.
Mixing 4 - 1 2
Setting the inlet presure with trigger on air to 25 PSI
The trigger knob is wide open, the patten is two turns back from wide open. To my knowledge when shooting it on a peice of paper looks consistant and even from top to bottom.
I am spraying the surface with 50% overlap as best I can, in arm legths, keeping air comin out of the gun when letting off the trigger at the end of the strokes.
Im doing nnothing but sprayin money into thin air :( What am I missing guys any ideas?
http://i126.photobucket.com/albums/p...l/P6050001.jpg
http://i126.photobucket.com/albums/p...l/P6050002.jpg
Lizer 06-05-2011 07:06 PM
You never said how far from the panel you were holding your gun. I won't give you advice because it's not my place to (I'll leave that up to the pro's here) but knowing that piece of information will help them.
Paintdian 06-05-2011 09:58 PM
I haven't measured a specific distance, but I spray approx. six inches away. What ever distance that I can see that the suface is becoming wet. I did do one light coat, let it tack, then did another light coat, tacked for a bit longer like 20 minutes, and then did a final one. It dosn't feel like I am putting it on too heavy but it just appears that the paint sprays on rough or something. I am following the steps as best I can but its just not working for me :pain:
Lizer 06-05-2011 10:40 PM
in the pictures it looks crunchy and dry like you're spraying too far away, making your swipes too fast, or the fluid setting is too restrictive.
deadbodyman 06-06-2011 05:26 AM
Or the surface is very hot...
Lizer 06-06-2011 07:20 AM
I just realized you said you sprayed light coats. You want this stuff to go on wet, just don't put it on too heavy that you get runs or sags. It probably looks dry because you are spraying the panel too dry with light coats. I have limited experience with SS but was taught to spray it wet (and that was just in some paint and body classes I took). I'm not a pro, so hopefully one of the pro's will weigh in on this. I'd always take their recommendation over mine.
50bowTie 06-06-2011 08:41 AM
no pro here but I've sprayed tons of paint :D Like said above. Two medium wet coats. NEVER dust coat or build up to a final flow coat. If you're reducer is matched accordingly to the temp your spraying in, you can flow this stuff pretty heavy on your first coat without running or sagging. Even over a 400grit surface.
swvalcon 06-06-2011 09:36 AM
From pictures looks like maybe your moving to fast, too fast of reducer, maybe try just a little more reducer about 10%. and slow down to where its going on nice and wet [just not to wet] On single stage I close off mixture screw and then open it up about 21/2 full turns this is a good starting point. If your putting down to much paint the gun can't spray it out smooth.And as said earlier if your doing this out side in the sun theres no way to not get peel.
Jim Rockford 06-10-2011 01:18 PM
I just sprayed a honda with some Nason SS 2k , tech sheet says first coat needs to be a medium coat,so I layed it on, I was scared of runs but it didn't , so Try it with a little heaver coat, and wait for it to tack up and Hit it again, Medium coats, Two spaying on a test panel just to see how much it takes to make it run and then you know how far not to go.
turbo t 06-10-2011 02:00 PM
bump the pressure upto 30ish and lay that on wet move closer to the panel you can also use a slower reducer/hardner
tommy
FRANKBULLITT 06-12-2011 06:41 AM
Use a slower reducer, Spray a test pattern and wet er down smooth
HalfOunce 06-12-2011 09:11 AM
If it is still pretty green...sand it with some 600 or 1000 n spray a couple of coats on it. be careful it will flow.
