bad thermostat - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2011, 03:04 PM
whojohnjones's Avatar
bad thermostat
my sbc doesn't get past 170 on cold mornings or in warm weather but gets to 195 on hot days in traffic..its has 195 degree thermostat. It only started been cool after car overheated from leaking water pump. when I replaced water pump the temps haven't been right since.
Old 10-07-2011, 04:40 PM
Siggy_Freud's Avatar
If you follow the gauge, and it's accurate, you should see temps reaching 190-200, the thermostat opening, and then the temps dropping back down. Are you entirely sure your gauge is accurate?
Bringing history and technology together.
Old 10-07-2011, 04:52 PM
yes its accurate..I have watched the gauge when the thermostat used to open but now it reaches 190 then stops..not up to 200 or so then drops
Old 10-07-2011, 05:54 PM
sqzbox's Avatar
My pipes are my music
What kind of fan are you using? It sounds like you have put together a real good cooling system! I have a 180* and that's as warm as it get's except when I'm running 65 on the hwy on a 100* day at 3,000rpm with 4:10's in the rear. Then it stay's under 200. During the winter I either have to put my custom clear plexiglass grill cover on it or change to a 195* stat or I freeze my butt off .
Old 10-07-2011, 05:57 PM
clutch fan
Old 10-07-2011, 06:07 PM
sqzbox's Avatar
The thermostatic clutch on clutch fans are rated for different temps two ways. one is the old fluid type and the other has a therm. spring coil. You might just have one on there that's rated to low there by pulling more air through the radiator than needed. Check with Auto Zone and see what different temp rating replacement clutches they have. I run a broad blade manual fan and that's why I have a too cool system for winter driving.
Good accurate temp check is shoot the therm. housing with a laser temp gun and compare with the gauge. My gauge is actually 2* cooler the temp gun reading.
Old 10-07-2011, 06:40 PM
but it was getting up to correct temp before
Old 10-07-2011, 07:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You are assuming the temp was "right" before- but the new pump may be that much more efficient than the old, worn out one. Differences in the impeller could make a difference in the temps.
Old 10-07-2011, 08:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Anytime you overheat an engine you need to replace the thermostat. it is cheap insurance. It is not unusual for them to go bad after an over heat
Chet
Old 10-07-2011, 10:08 PM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
Your thermostat is stuck open.Easy way to check it when the motor is cold,open the radiator cap and look while it's running,if the fluid on running across the radiator top, fast.
Good Luck,Paisano
Old 10-07-2011, 11:35 PM
yes it has constant flow from heater core when cold
Old 10-08-2011, 05:58 AM
If you are looking at flow in the hose coming from the heater core to a fitting on the radiator, that does not mean the thermostat is open. When SBC cooling is plumbed with that direct hose to the radiator (quite common), it always has flow from the heater core.
I think that with the thermostat opening early, your clutch fan is controlling the temp in hotter weather. The thermostat is opening early at about 165-170, so in cool weather that is the temp where it stays. In hot weather it opens, and with minimal cooling from the fan the temp continues to rise until the clutch fan kicks in and the extra air flow pulls the temp down.
I would recommend a high flow thermostat if you can find one (Robert Shaw, Mr. Gasket, etc.). However, the local places did not have the 195 degree version of the high flow and I had to get it mail order from Summit.
Bruce
What are the advantages of running a 180* thermostat vs a 195* thermostat? batman09 Engine 7 01-08-2011 11:19 PM
best thermostat smlblcks10 Engine 38 01-31-2006 11:48 AM
Do you NEED a thermostat? voodoosurfer Engine 46 11-18-2005 10:03 AM
Thermostat black66 Engine 3 08-20-2005 11:49 AM
new thermostat astrops Engine 2 05-13-2004 08:48 PM
